brake bleeding
Old 03-10-2007 | 01:24 PM
Dj7763's Avatar
Dj7763 is an unknown quantity at this point
Default brake bleeding
i have a 98 gmc jimmy i'm assuming its going to b the same on a blazer but how do u bleed the brakes?
Old 03-10-2007 | 04:55 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: brake bleeding
Have a helper pump the pedal 3-4 times, then start at the RR, and open the bleeder. Close it when the fluid stops flowing, and repeat. Do this until all the air is out, or you have clear clean fluid comming out. Then move onto the LR, RF, LR. Good luck.
Old 03-10-2007 | 11:36 PM
2Tone's Avatar
2Tone is an unknown quantity at this point
Yeah, its best to start with the furthest one from the master cylinder (RR, LR, RF, LF).
Old 03-10-2007 | 11:38 PM
swdockter's Avatar
swdockter is an unknown quantity at this point
Don't forget to keep the master full of fluid. You let it get dry and you'll have to bleed the master as well.
Old 03-10-2007 | 11:41 PM
2Tone's Avatar
Also if the master gets empty youll get air in the system so youd have to bleed them again anyways. so yeah, keep it full.
jnail
03-04-2009 01:20 PM
portcqb
03-13-2008 05:25 PM
jess1327
03-12-2008 12:37 PM
Hanr3
11-23-2007 09:26 PM
97Blazer15
04-26-2007 08:21 PM
