Brake pedal goes to floor while running
Old Jun 18, 2022 | 03:58 PM
New Guy_4's Avatar
New Guy_4 is on a distinguished road
Question Brake pedal goes to floor while running
Hello all,
I recently picked up a 1987 S10 Blazer and I'm having brake issues. My pedal goes to the floor while the vehicle is running, however while it is off I have all the pressure in the world. I have replaced the master cylinder, brake booster, vacuum check valve, and both rear wheel cylinders. I have bled the system and I know for sure that there is no air. Has anyone else had this problem and if so how did you solve it? I'm at a loss and the only other part I can think that could be bad is the proportioning valve. Thanks in advance.
Old Jun 18, 2022 | 04:45 PM
Does your year have ABS brakes? If so, there could be an issue with the ABS system not being bled correctly. Just a thought.
Old Jun 18, 2022 | 11:30 PM
New Guy_4's Avatar
It does not have abs, it's too old.
Old Jun 19, 2022 | 12:31 PM
Hess13x's Avatar
Id look for a vacuum leak in the power brake system.
baxter22
Nov 6, 2012 02:24 PM
baxter22
Aug 27, 2012 03:44 PM
princered72
Jul 29, 2012 03:14 PM
ryito1122334455
Oct 8, 2011 03:08 AM
lroman3
Apr 16, 2010 02:51 PM
