C clamp for torsion bar?
Old Jun 21, 2008 | 04:14 PM
jrocks607's Avatar
jrocks607 is an unknown quantity at this point
Default C clamp for torsion bar?
Can i use a c-clamp to change torsion keys?
EDIT: Combining double posts. Please use the edit function to add information to an existing post rather than starting another. Thank you! TBB.
I have heard that you can use a c-clamp toload a torsion bar to change the key, well this worked on the drivers side after 2 c-clamps,but theexaust is in the way on the passengers side. Twists clamps until theyre useless.4 clamps now. How did you guys do it? Do i really need the $100+ unloading tool? Please help. Truck has been on stands for 2 weeks now.
Old Jun 21, 2008 | 04:26 PM
burak sozer's Avatar
burak sozer is an unknown quantity at this point
Default RE: C clamp for torsion bar?
yes I think so if its in suitable size.
I have done with a transmission jack ( the ones to work on lift)
Old Jun 21, 2008 | 08:53 PM
jrocks607's Avatar
I have a 2 jaw puller that i will try this weekend,but i have to notch(cut a very small spot) off the crossmember for the puller to fit. By the time its over i think i should have bought the tool. Not a big fan of a 1 time tool.. Burak, how did you use a tranny jack to load your bars? A pic of what im working on.
[IMG]local://upfiles/11115/3BD86327038F42C68C24E9451EC3BED3.jpg[/IMG]
Old Jun 22, 2008 | 05:45 AM
Sorry for late reply, i live in overseas, 7 hrs difference.
i did my job in my friends garage, he has a two post lift, and
http://www.harborfreight.com/cpi/cta...emnumber=33680
the top part of the jack is removable, when we remove it there is a jacks shaft.I used one spare lug nut upside down ( conical side is up and fits the hole in key) and lift the jact till get the tension out of the retainer. ( while the car is lifted)
Another tool you can produce ; if your have a spare U shape leaf spring mounting part, you can get 1"x1" steel block, drill 3 holes, two of them to match the U bolt ends, one in center of them, you have to tap threads to install a long bolt ( which will be opposite of a puller, actually it will be pusher) , hang U shape part over the traverse, install 1"x1" part to both ends, you have one hole left, this will be pusher bolts place, install a pusher bolt ,once you turn the bolt it should get the tension out of bars.
Sorry for my poor english, I hope i could explained properly.
Old Jun 27, 2008 | 01:36 AM
jrocks607's Avatar
Thanks for the help guys, i finally got it in.
Old Jun 27, 2008 | 04:07 AM
Im glad you have made it safely.
Enjoy your ride with it
azzr2
Mar 25, 2012 04:19 PM
ferret13sj
13
Nov 15, 2011 09:26 PM
TRUNK
May 27, 2011 08:56 PM
diamondjimmy00
Oct 18, 2010 12:12 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
