can i upgrade from a stock 15'' rim to 17'' rim without any extra modification
Old Mar 3, 2013 | 03:19 PM
evuldrporkchop's Avatar
evuldrporkchop is on a distinguished road
Default can i upgrade from a stock 15'' rim to 17'' rim without any extra modification
sorry no option for wheels from what i could tell
Old Mar 3, 2013 | 03:20 PM
continued: or even a 19'' rim
Old Mar 3, 2013 | 08:36 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
Please edit your post before bumping.
But any way there are a lot of combinations on what you can do. Not knowing if you have a 4x4 or 2x4. But as long as your keep your tire close to the same size height wise as the stock tires you should fine. Try to keep the backspacing/offset close to the stock by using spacers and you should be ok. check out camaro/firebird/vette rim swaps as I have seen 20" vette rims on syclones/typhoons fit.
Old Mar 3, 2013 | 11:16 PM
El_Beautor's Avatar
Almost any rim size is possible. It just depends on how much work you want to do. Post up some specs about your truck, and any specific rims you're looking to fit and maybe we can help more.
Old Mar 4, 2013 | 01:20 AM
ohsofly's Avatar
I put 17s on mine, they bolted on and fit fine. they stick out a little more than the stock wheels did, but that's what I wanted.
Zr2Newbie
Lifting Tech
Feb 19, 2013 06:34 PM
krunk357
May 5, 2012 09:28 PM
vince_wonk
Feb 21, 2012 03:29 PM
iamchevyman5
Nov 7, 2010 01:20 AM
Spectreblazer
Feb 13, 2010 04:59 PM
