Changing Transfer case fluid.
So I got 3 quarts of the auto trak II fluid for my 2001 blazer. I just got the 4wd working so I figured id do an fluid change on the differentials and the transfer case. When I opened the upper part which is used to fill up the transfer case, transfer case fluid (red colored) spewed out meaning there was extra fluid since the line is supposed to be under the hole opening. I closed it immediately but I want to change it soon and there is no way I can over fill it like it was. Will it be okay if I fill it up until it runs out of the opening?
If the transfer case was over the fill port, then the input seal on the transfer case is bad, allowing transmission fluid to push into the transfer case. The level inside the transfer case only needs to be to the bottom of the fill port. Any more than that and it is over full.
I assume you have the 4-button 4wd switch (NV236) since you stated that you purchased Autotrak 2 fluid. The 3-button system (NV233) uses standard ATF rather than the more expensive Autotrak 2.
This same thing has happen to my blazer. After a lot of research i finally figured out where all my trans fluid was going. The inner seal goes bad and the trans fluid leaks into to transfer case. If you do not want to replace inner seal make sure you drain the transfer case to the normal level. If not the vacuum system can suck up the fluid causing major problems. It is very labor intensive the whole transfer case must be dropped to change seal.
Well I just figured that I had this problem. And what kind of "major problems" does it cause when sucked up by the vacuum system? When my 4wd wasn't functioning my mechanic said he had to replace cables because it wasn't disengaging due to "debris" so maybe it was caused by the fluid in there
If the vacuum system does suck up fluid into the system it could get into components of the vacuum system such as HVAC actuators and other components that use engine vacuum. I'm not sure if fluid could of caused the problem you are referring to. If you do not want to replace the seal just keep an eye on your trans. fluid level and check to make sure the transfer is not overfilled a great deal every 6 months or so.
Just changed my transfer case fluid, fluid did come out the fill hole but not sure if you hat was because the front wheels were up on ramps? Took it off ramps to refill I see no easy way to fill it back up ended up routing a 4' piece of hose from the fill hole to out from under the truck to about half way up the drivers side door, poured the fluid into the hose and let gravity do its thing. Seems to be a controversial topic but I did use royal purple synchromax instead of autotrak 2..
I checked 8 months after the fluid change and when I opened the top plug only a drop or two came out.. I am not sure why there was a build up there in the first place bit I think the seal is working fine
I know that most of these posts were from months back I was just adding that so other people on the sight would be aware with a badly blow seal the Xfer case can fill up fast and needs to be checked often until seal is replaced so no further damage is done thu out the rest of the vehicle
Flyfishen
Jun 18, 2019 11:22 AM
jamextras
Oct 13, 2012 06:19 PM
DaleA
Jan 13, 2009 08:50 PM
