steering issues
Old Feb 20, 2016 | 11:38 PM
infidel89's Avatar
infidel89 is on a distinguished road
Exclamation steering issues
new to the forum and in desperate need of some help. my steering seems to float left and right and its not as responsive as it should be. any clue as to what might be causing the issue?
Old Feb 21, 2016 | 04:45 AM
newguy's Avatar
check your tie rods, pitman arm ,idler arm rag joint on steering shaft. could be a number of things but start here
Old Apr 3, 2016 | 02:49 PM
moosehauler05'blaz's Avatar
moosehauler05'blaz is on a distinguished road
Yup I would lift the truck up and see if you can move the tires Hands at 9 and 3 and 12 and 6 move it back and forth if theres any play have someone look behind the wheel and see whats moving those are the parts that need to be changed out if theres any road noise sould chance it could be a wheel hub too they also make play in the steering ..last would be rag joint adjustment which is a nut and a allen key ..Loosen the nut and a very small 1/8 turn of the key clockwise and close the nut again best to have a mech do it
ctyler
Aug 25, 2020 04:06 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
SteveCZ28
Oct 26, 2009 10:34 AM
