Checking ball joints
Old Apr 22, 2008 | 01:29 PM
WLB's Avatar
WLB
WLB is an unknown quantity at this point
Default Checking ball joints
I recently purchased a 93 S10 Blazer with 2 wheel drive and 220,000 miles. I set the front end up on jackstands positioned under the lower A arms and grabbed the tire at the top and bottom and tried to move it in and out. It felt solid with no play.
I then removed the wheels and discovered that it still had the factory rivited in upper ball joints. I was aware that S10 have an issue with ball joints and was really surprised that these still felt good.
My question is: Is what I did the correct way to diagnose a bad ball joint. GM Metric cars have nearly identical A arms, spindles, and brakes and that is the way I have always checked ball joints on my Metric framed race truck or anything with similiar syspension.
I used the Search feature and didn't find anything other than ball joints are a frequent repair.
Old Apr 23, 2008 | 01:24 AM
Chevy Lover's Avatar
Default RE: Checking ball joints
Make sure that your jackstands are out as far as you can get them without touching the tires. It sounds like your checking them correctly.
I also take a bar and pry up under the tire to see if there is any movement up and down.
[IMG]local://upfiles/2910/D581D1F3CDC7431B887FDB11A332EF64.gif[/IMG]
Old Apr 23, 2008 | 07:41 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Yah they sound good, but I am very surpised that yours are good at 220k miles. They must have been really greased their entire life and being a 2wd definetly helps.
Old Apr 23, 2008 | 09:11 AM
Ludachrls83's Avatar
Ludachrls83 is an unknown quantity at this point
I'm going to be checking my front end this weekend just to see how everything has held up after 80k miles. I have a 2000 2dr 4x4. I am the second owner since 45k miles and don't think there was any work done to the front end before I got it. Can I get some detailed info (maybe some pics) as to what I should be looking for and what components to check out? From this post, I know how to check the ball joints (jack up and see if there is any play in the wheels) but I don't know what the ball joints look like. As much info would really be appreciated.
Old Apr 23, 2008 | 10:54 AM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Same here. This is something I've been wanting to check soon, since I'm at 166K miles. I also did a search and came up empty on what I was looking for.
Old Apr 24, 2008 | 08:24 AM
WLB's Avatar
WLB
Thanks Chevylover, I knew I forgot something. I went back and used a pry bar under the wheel and they still checked out ok. I believe that it had been greased regularly because grease came out every joint on the first pump of my grease gun.
My son's 4 wheel drive 94 with 160,000 miles has a replacment ball joint on the left side and the stock rivited ball joint on the right side. It checks good also.
Old Apr 24, 2008 | 09:48 PM
94blueknight's Avatar
94blueknight is on a distinguished road
ya i know my blazer had been well greased and still has the stock ball joints at 136K mi. when i went to grease it when i did my oil change at 2500 mi i would only get a few pumps b4 it started comin back out
Old Apr 25, 2008 | 06:38 PM
4x4blazerguy's Avatar
To check UPPER BALL JOINTS you have to take all weight off suspension. Put your stands on the frame letting the sit without weight.
Old Apr 29, 2008 | 08:13 PM
Butts's Avatar
Butts is an unknown quantity at this point
The way I check the ball joints are the same, except to check the top you would push on the bottom side of the tire and wiggle the top. The opposite goes with the bottom. Youwillfeel or hear the loose ball joint if there is one.
LoLoS10Blazer87
Suspension Tech
Sep 19, 2008 07:43 PM
tom1337
17
Mar 12, 2006 10:44 PM
TDQ
Suspension Tech
Jan 9, 2006 01:50 AM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
hdlogistics
Suspension Tech
Dec 2, 2005 10:53 AM
