Clunk/pop sound from front end
Old Aug 11, 2007 | 03:48 PM
turboxb9s's Avatar
turboxb9s is an unknown quantity at this point
Default RE: Clunk/pop sound from front end
the outer brake pads on these vehicels have these little tabs which need to be bent inward after installation to keep the outer pad from shifting whild driving. Your mechanic should be aware of this as it is really common and usually this problem will cuase a noise once when stepping on the brake in forward and will not do it agian until you put it in reverse and hit the brakes.
if your rotors are warped as they say NORMALLY you will also get a lot of shakeing while applying the brakes at highway speeds. Check for that and if you have a pulsation in the brakes at high speeds and also the steering wheel shakes a little while they pulsate then I would definately have the front rotors replaced.
choover82
Jan 14, 2012 01:02 PM
janddcunningham
Apr 29, 2011 08:43 PM
kyjonesy
Feb 25, 2011 08:35 PM
Monstro
Aug 13, 2008 03:26 PM
ShadowHawk
Suspension Tech
Feb 11, 2007 09:50 AM
