Clunking when rear braking and clunking when foward braking
Old Sep 10, 2020 | 10:54 PM
BlazyblazerCAN's Avatar
BlazyblazerCAN is on a distinguished road
Default Clunking when rear braking and clunking when foward braking
Hi i have a 2000 chevy blazer LS and I have a problem with the lower or upper control arm. When I brake from the front nothing happens, everything is normal. But when I back up a thud is heard. I put the vehicle on drive and I arrive at a stop sign and again the dull noise occurs and this from the driver's side. Same thing when I reverse what is the problem? Can anyone help me. Thank you!
Old Sep 14, 2020 | 10:47 AM
It sounds like you likely have it narrowed down to a front end component. There are many ways these could fail such that you get clunks. Off the top of my head I'd think a bad control arm bushing but you'd have to jack up the front and visually check all the parts. You will also have to wiggle all the parts by grabbing the wheels and seeing if anything is loose. Keep in mind that some of the parts are under tension due to the springs so this is were the visual inspection comes in.
Old Dec 15, 2020 | 05:41 PM
jimspahr@msn.com's Avatar
Is your 2000 Blazer LS 2WD OR 4WD ? This answer helps you get accurate info.
natem504
Nov 4, 2016 08:46 AM
upmaine
Jun 26, 2012 02:58 AM
brendan127
Oct 20, 2011 04:28 PM
jman_08
Dec 24, 2008 01:14 PM
sndro666
Dec 18, 2007 07:22 PM
