control arm question?
Is it possible to put a 2wd lower control arm on a 4wd frame and use a coilovers in place of the t-bars. Or use coilovers with the 4wd lower control arm?
you cannot use 2wd control arms on a 4wd.
Yah the purpose of the tbars is to replace the coil that needs to go where the cv is. So if you want 4wd you cant do it,if u make it into a 2wd you can probably get it to work.
I saw on another website that had a 4wd frame with custom conrtol with coilovers in the front.
well with enough money anything is possible. what are you trying to accomplish by doing this??
**Edit i googled SyTy performance and found a coil over kit thats made for the Syclones/Typhoons that you may be able to retro-fit onto your blazer but the kit is $1500. like i said earlier, if your pockets are deep enough everything is possible.
er0ck273
11-14-2014 02:48 PM
bansheedave
03-19-2012 05:11 AM
cartunez2004
04-09-2011 09:01 PM
