CV axle or hub bearing???
Old Jun 4, 2008 | 07:01 PM
95grn4dr's Avatar
95grn4dr is an unknown quantity at this point
Default CV axle or hub bearing???
I have a whirring noise/vibration start at around 20mph quites down at 25 and starts back up at 50,I have narrowed it down to the front end as when I engage the 4wd the vibration gets worse and when I disengage the 4wd about 20 seconds after I push the 2hi button the front end makes a clunk like a bearing binding up and releasing,I am thinking that one of the hub bearings are shot or could this be a dying cv axle???I dont have any clicking/poping while turning that would indicate the joints are worn and the boots are intactbut as I said I have a odd clunk when I disengage the 4wd.Any ideas???
Old Jun 7, 2008 | 02:14 AM
95grn4dr's Avatar
Default RE: CV axle or hub bearing???
Solved my own problem turned out to be a shot rear wheel bearing........even though I could swear I heard it from the front end the axle shaft had a nice groove worn into it when I removed it,I will be replacing the bearing tomorrow
Old Jun 7, 2008 | 09:52 PM
95grn4dr's Avatar
All of the above problems solved.....including the clunk when I disengage the 4x4.Just thought that I would share my situation with others as it REALLY felt like a front hub/bearing assembly NOT a rear wheel bearing.
jmaynard
Jul 12, 2011 01:03 PM
KLBlazer07
13
Jan 14, 2007 04:16 PM
Marcin
Nov 9, 2006 11:31 AM
Chavez96
Sep 20, 2006 04:04 PM
greengoose89
Aug 3, 2006 07:32 AM
