CV axle jammed 2002 blazer
Old Oct 28, 2019 | 10:48 AM
Crazyc11's Avatar
Crazyc11 is on a distinguished road
Default CV axle jammed 2002 blazer
Cut to the chase. I'm new here Hi.
Driver side cv shaft jammed I have 2 peice removal..both tools are bottoming shaft will not pop . Any help much appreciated. Dont need a week conversation. I just need it done. Srry I don't have a sense of humor
Old Oct 29, 2019 | 01:02 AM
It's not quite clear. Are you trying to remove the axle or install it?
Old Oct 29, 2019 | 04:35 AM
Ex-Calif's Avatar
Ex-Calif is on a distinguished road
Put a very large screwdriver on the edge of the black collar - use a 3 pound sledge and drive it straight out. Should be able to get an angle on it. I just did this on my lift project.
Old Oct 31, 2019 | 01:44 AM
hurleyii's Avatar
hurleyii is on a distinguished road
Man I’ve done it to a million cars and I actually broke my inner axle on passenger side trying to get my original 3.42 front diff out. Cv shaft would not come out to save my life.
Old Nov 1, 2019 | 09:35 PM
2001ZR2's Avatar
I use a pry bar as it has the cap on the to hit with hammer but once you get it moving it will keep moving.
Have you removed the other end from the hub? If not I would recommend it.
Old Nov 2, 2019 | 11:54 AM
I've used a short piece of 2x4 with a large hammer. I could see also applying pressure by a pry-bar while also wacking it with a hammer.
aerovette99
Nov 14, 2016 08:07 AM
porkfriedrice
Sep 2, 2016 08:48 PM
weaponofchoice
Apr 25, 2014 08:40 PM
livinterror
May 2, 2009 10:29 AM
bexxdad
Oct 5, 2008 12:05 PM
