diff service help!!!
Old Dec 30, 2008 | 07:43 PM
Default RE: diff service help!!!
ORIGINAL: swartlkk
8 point socket. Once you have a set, you will find all kinds of uses for them. Just measure the plug and make sure that it is in the set you buy.
From the sounds of it, someone used a plumbing plug on your diff...
No, I would say that a prior owner swapped it out for whatever reason. The square plug is most common in plumbing applications due to the heavy use of pipe wrenches. It cannot be inside out as this plug is an NPT thread which is tapered.
Old Dec 30, 2008 | 07:55 PM
greenjimmy's Avatar
greenjimmy is an unknown quantity at this point
ok, thanks, i did not know. so, would auto zone or advance carry a stock replacement plug so i can correct this?
Old Dec 30, 2008 | 08:03 PM
I do not think it is something that needs correcting unless you do not get the tools to properly remove/reinstall the current plug. Any hardware store should have a plug that will work. It will likely have a hex instead of a square bore though.
Old Dec 30, 2008 | 08:05 PM
greenjimmy's Avatar
ok, thanks
Old Dec 31, 2008 | 03:04 AM
WolfPack's Avatar
So...if this seems to be a household plumbing fitting...made for use with a pipe wrench and/or crescent wrench....why not use the pipe wrench and/or crescent wrench to get it off?
Old Dec 31, 2008 | 03:21 AM
Access. The webs on the diff make it near impossible to get a wrench on it. If the square protrusion is long enough, you may be able to use an open ended wrench on it, but I am sure you have already tried something like that.
For illustration purposes, here is a picture of the diff where the fill plug is:
Old Dec 31, 2008 | 03:39 AM
WolfPack's Avatar
NEW PLAN. Gear wrenches. Everyone could use some nice gear wrenches. Espeically you, with your oddly replaced fill plug with limited access.
Old Dec 31, 2008 | 08:18 AM
greenjimmy's Avatar
yup, thats how it looked when i changed my friend's diff oil. i figured that mine looked like that so i got all the stuff i need before i looked at it. well, i am going to run out to the parts store this morning to get a either an 8 point socket or some square tubing. thankss for all the help guyz. swartlkk, i read your diff service to make sure i was got all the right stuff and what not, just wondering, did you special order the diff cover or the dealership have it in stock? anf, how come you didn't paint the cover?
Old Dec 31, 2008 | 12:30 PM
Dealer had to order it. They had it the next day. The gaskets they had in stock. I did not paint it because I did not have time.
Old Jan 1, 2009 | 04:14 PM
greenjimmy's Avatar
ok, thanks, i went out and got a new cover today and i figured out the the fill plug was an 11/16. so i am finally set now. thanks for all the help guys.
