Differential cover bolt sizes
Old Jun 22, 2010 | 01:53 PM
jstein's Avatar
jstein is an unknown quantity at this point
Default Differential cover bolt sizes
Hi everyone,
I'm preparing to replace the differential cover on my '02 4dr 4x4 push button blazer. I would like to replace the bolts with stainless. This is my only means of transportation so pulling one bolt and driving to the hardware store isn't exactly an option. Does anyone have any idea what length and thread sizes the bolts are? Thanks in advance for your help.
Old Jun 22, 2010 | 08:53 PM
abig84's Avatar
just pull the very top one out youll be fine. heck if the cover has never been off you can probably pull them all off itll be glued shut.
but seriously you can get away with just taking one out of the top with no problems at all
Old Jun 22, 2010 | 09:14 PM
Frankiesurf's Avatar
Frankiesurf is on a distinguished road
I would have to assume they are metric bolts.
I will have to do this eventually as my cover is a little wet. It is not dripping but still wet. The fluid in the rear is still almost full so I have some time before it needs to be done.
I saw that the top bolt was a little loose so I went to tighten it and realized some one tried this before and stripped it. There is a newer SAE bolt in it with two lock washers. It looks like it may only be the bolt that is stripped, for now. Hopefully this is the case. I am not looking forward to retapping the thing on my back. At least it is fairly easy to get to.
Please post up what you find out.
Old Jun 23, 2010 | 07:36 AM
jstein's Avatar
To touch upon what both of you have said, I had considered removing the top bolt. Though I'm not crazy about the idea, it may be the only option. My cover is actually pretty bad. It has been wet since I have owned the car for the past 2 years. It is now starting to drip so I'd like to tackle this before I burn out my differential. The replacement cover I got is from Rockauto DORMAN Part # 697701 http://www.rockauto.com/catalog/x,ca...,parttype,2306
This cover comes with a black gasket (not sure what its made of). It appears that someone did this job before and used an orange RTV like gasket sealer. I'm not sure if they used it in conjunction with a real gasket. Is it advisable to use both or should the paper gasket be enough?
Old Jun 23, 2010 | 06:10 PM
Put a thin layer of RTV on the differential cover put the gasket on and let cure for 10 or so minutes. This will help hold the gasket in place when installing it and aid in the sealing of it.
Using just RTV is not suggested, use the supplied gasket as well.
Bagherra
Mar 15, 2015 10:13 PM
er0ck273
Jun 2, 2013 05:56 PM
SlydinClyde
Oct 24, 2009 10:42 AM
GregC5
Mar 22, 2009 08:48 PM
Ryanesque
Tires and Wheels
Oct 22, 2008 06:22 AM
