Differential fluid amount
Old Jan 6, 2021 | 09:21 PM
Mel327's Avatar
Mel327 is on a distinguished road
Default Differential fluid amount
I have a 85 s10 blazer 4wd and I'm needing to know how many quarts of fluid the rear differential holds? I know you usually fill it up till it drips out of the fill hole. But mine was over tighten and someone welded a bolt to the plug and overtightened it again and I broke the bolt trying to get it loose, so I took the rear end inspection plate off and drilled it and welded a nut and bolt setup to it, now I can fill it up from the back cover but I'm sure it's sets higher than the original one and I don't want to overfill it. Any help is really appreciated.
Old Jan 10, 2021 | 10:34 PM
Mods's Avatar
honestly the only big issue with overfilling a differential of this type is A wasting fluid and B it will **** out the vent hose, i believe its something like 2 quarts or so if you are worried about making a mess in the driveway.
Depends on axle size, of course an 8.5 Saginaw will take more then a 7.625.
Old Jan 11, 2021 | 09:59 AM
Measure the distance from the bottom of the original fill hole to the ground. Then, make a mark on the back of the cover at the same height. Use a zip tie or a piece of wire as a dipstick to tell when it's up to the mark you made.
Schrade
Oct 3, 2016 04:43 PM
LannyL81
Oct 7, 2014 06:48 AM
sirfunkeybut
May 1, 2011 10:04 PM
tkf5651
Jun 2, 2008 09:43 PM
KennyJonson
Dec 26, 2006 06:09 AM
