differential HELP?!?
Old Sep 11, 2012 | 09:10 AM
wvboy18's Avatar
wvboy18 is on a distinguished road
Default differential HELP?!?
2001 chevy blazer
Ratio 3.42
10 bolt
my diff fluid ran dry and I didnt know it, it busted either the outer or inner pinion bearing but thats all I can tell thats wrong with it, should I put a new pinion gear and bearings in it or just a whole new rear end? I'm hearing 2 different things and figured I would ask on here..really need this answered...thanks in advance.
Old Sep 11, 2012 | 09:46 AM
chris015's Avatar
If you have access to a cheap pull it yourself yard,then just replace the whole diff (make sure you still have 3.42 though). Shouldnt cost more then a Benjamin
Old Sep 11, 2012 | 11:30 AM
50lb_cat's Avatar
+1, rebuilding a diff isn't a DIY job if you don't know what you are doing. Replace the whole rear end from one that has the same gears. Just look up the RPO code in your glove box.
Old Sep 11, 2012 | 03:38 PM
El_Beautor's Avatar
The RPO code to look find for your truck for the 3.42 gear rear end is GU6.
Drew4711
Oct 6, 2012 12:47 PM
photogtimmyo
Apr 15, 2009 07:18 PM
salvy
Sep 18, 2008 02:23 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
tilley101
Jan 7, 2008 07:43 AM
