do both tires spin??
Old Nov 19, 2005 | 06:38 PM
Jhop16's Avatar
Jhop16 is an unknown quantity at this point
Default do both tires spin??
heya i kinda noticed that my trucks right rear tire is the only one that actualyl has power?... is that the way it should be or is it a problem, and if thats the way it should be then does 4wd only meen 2wd??
Old Nov 20, 2005 | 02:34 AM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default RE: do both tires spin??
no thats normal considering you have an open open differential gearing in there if you floor it around a left hand turn your left wheel will spin to get both tires to spin you would need a locker
Old Nov 20, 2005 | 10:10 AM
Are you saying that when you get it to spin, that only one tire spins (peg-leg burn-out)? Then yeah, you've got an open differential in the rear. If you had a limited slip, then you would spin them both.
I assume that we're talking about a 4x4 here, but what year? Also, you can identify the options on your vehicle by decoding the RPO list. On my 2000 Bravada, the RPO list is in the glove box. Also for my Bravada, G80 is the RPO code for posi-traction rear diff.
When in 4wd, you shouldn't have a problem with only 1 or 2 wheels spinning, unless you are in some serious traction trouble (ie. 2 tires w/ high traction and 2 tires with no traction).
Good Luck
88s10Blazer
Apr 24, 2011 04:47 PM
stephensh
Sep 27, 2009 10:06 AM
bigdaddykane93
Aug 3, 2009 03:03 PM
redblzr4x4
Jul 14, 2009 02:10 PM
djkrash
Dec 7, 2007 01:29 PM
