Don't know better here or DIY
Old May 8, 2008 | 07:04 PM
Blazerx85's Avatar
Blazerx85 is an unknown quantity at this point
Default Don't know better here or DIY
I am getting ready to change out upper and lower ball joints, idler arm, and pitman arm. Just wondering how hard this will be or just time consuming also and tips and or tricks will definitly be appreciated.97LS 4x4Thank you
Old May 8, 2008 | 07:37 PM
TripleBlackBlazer's Avatar
Default RE: Don't know better here or DIY
Some members have handled doing the ball joints just fine while others (myself included) have just paid to have them done.
If they are the stockers then you will need a good bit of time to get the rivets out by either using air chisel (easiest) or BFH and chisel along with a drill. Some have drilled the center of the rivets out and hand chiseled the rest of the way.
Here is a thread that has a decent amount of instructions but not too many pictures. Should be helpful nonetheless.
As for the other parts you're replacing, you can also search using the part names as your keywords.
Old May 9, 2008 | 09:30 AM
Blazerx85's Avatar
Thank you very much. I have every tool you can thing of to do it so I hope it goes pretty smooth
chris015
Engine & Internal
Jul 25, 2011 09:13 PM
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
havrelm1
Jul 24, 2008 09:26 PM
cvcmama22
Apr 7, 2008 06:41 AM
grubdub761
Oct 18, 2007 02:48 PM
