Drive shaft problem!
Old Apr 22, 2013 | 12:24 AM
Quintae Brooks's Avatar
Quintae Brooks is on a distinguished road
Default Drive shaft problem!
Need help; I have a92 full size Chevy Blazer. It has a manual transmission and when I am shiftinginto first, and from first to second there is a loud knocking sound andvibration that feel like it is right under the center console. However if I easeon the gas and baby it, there is no knocking. When I looked under the truck, were the frontof the shaft meets the rear of the transmission; I see marks above the shaft onthe sub frame. It seems as if the drive shaft (when I am applying to muchtorque form 1st and 2nd gear) is knocking against the subframe. And ive also just notice that the rear of the transmission is leakingbut it is not transmission fluid. Not sure what would cause that to happen? Anyhelp what so ever would be great!
Attached Thumbnails Drive shaft problem!-541425_10100553834693020_1808087890_n.jpg   Drive shaft problem!-931188_10100553834757890_1912546286_n.jpg   Drive shaft problem!-164927_10100553838570250_1258103026_n.jpg   Drive shaft problem!-430474_10100553838545300_932398522_n.jpg
Old Apr 22, 2013 | 09:40 AM
chris015's Avatar
Looks like rear bearing in trans has failed and caused lots of play.
Old Apr 22, 2013 | 05:06 PM
xgiovannix12's Avatar
How is the trans mount looking... From the looks of it the trans is shifting way to much when changing gears
Blade_24k
Feb 26, 2014 03:03 PM
Tony H
Sep 7, 2010 07:45 AM
lizzj70
Jun 23, 2010 06:57 PM
newbie
May 31, 2007 10:45 AM
wormburnr
Nov 4, 2006 03:42 PM
