Driving without front driveshaft
Old Nov 14, 2025 | 10:37 PM
Default Driving without front driveshaft
Have any of you driven with the front driveshaft removed?
I'm thinking of removing it to help isolate the source of vibration I have that is at the frequency of the driveshaft.
Old Nov 15, 2025 | 06:39 PM
FYI: The answer is Yes, you can drive without the front drive shaft installed. There is a nice seal around the front output shaft. I wouldn't drive with it out for long since the output shaft from the transfer case that is splined could get damaged if left exposed.
I discovered that my vibration was gone with it out. The u-joint was pretty tight so I think that was the issue.
Old Nov 18, 2025 | 02:23 PM
El_Beautor's Avatar
Looks like you've answered your own question. So does this mean that your search to eliminate the vibrations is finally done?
Old Nov 18, 2025 | 02:32 PM
I sure hope so!
I got the replacement drive shaft an hour ago. I'll report back after I install it and do my test drive!
Old Nov 18, 2025 | 03:31 PM
int3414's Avatar
int3414 is on a distinguished road
i probably would not have though to buy a new one,but sounds like a good idea...did yours have a rubber like joint
Old Nov 18, 2025 | 03:52 PM
There is a CV joint with a rubber boot at the transfer case end and a u-joint at the front axle end. I thought about replacing just the u-joint which would have been MUCH less expensive, but then I realized that the CV joint was also 26 years old and that even though sealed, the grease would have been quite old. I looked at the price of replacement CV joints for the front drive shaft and then factored in that I really needed to get this done quickly due to the weather getting bad and although still less expensive to rebuild the old one, I didn't want to have to deal with the uncertainty of the my rebuild not working correctly. I also considered having the local transmission shop rebuild it for me but then that would have added an extra cost and a bit more delay. So in short, I'm spending about $100 to $150 extra dollars extra for being able to get this done quickly and for peace of mind.
Now, if it had been June and my other car was running fine, I would have likely tried to do the rebuild myself since I could have afforded the time to do so.
Old Nov 19, 2025 | 11:32 AM
El_Beautor's Avatar
Having 4wd for winter is a major consideration. I completely understand that one!
christine_208
Oct 22, 2025 08:11 PM
REPO1266
Sep 15, 2019 09:07 PM
1997 tricky1
Jan 1, 2011 08:40 PM
scrmmealuvsong22
Apr 25, 2010 03:41 PM
matthew116
Aug 3, 2009 06:20 PM
