Engaging in 4HI
4LO will typically thump/clunk in due to the gear ratio change. That sounds normal.
What do the dash lights do when you are attempting to engage 4HI? If you have Auto4wd, try running through the OBD2 Non-Automatic Transfer Case Diagnostics and let us know what the outcome is.
The other thing to check/try is to check/clean the electrical connections at the switch (in dash), TCCM (transfer case control module - behind the passenger side kick panel), and at the encoder motor (on the transfer case). We have had some members that had similar problems and it was a loose connection at the switch. Others have had corrosion issues at the connector on the TCCM.
Hope this helps!
Hope this helps!
seriosbrad
Nov 7, 2015 09:08 PM
tambo
Mar 4, 2005 05:44 PM
