Engaging in 4HI
Old Jan 26, 2008 | 09:24 PM
Hogwash's Avatar
Hogwash is an unknown quantity at this point
Default Engaging in 4HI
It is electric 4wd. When I try to engage in 4HI it does nothing, going slow or dead stop in N. 4Low works when I am in N you hear the clunk. Any Ideas on why the HI wont work???
Old Jan 29, 2008 | 12:24 AM
rastaskater's Avatar
rastaskater is an unknown quantity at this point
Default RE: Engaging in 4HI
i dont think its supposed to CLUNK my t-case makes a small clicking noise. thats about it.
Old Jan 29, 2008 | 03:55 AM
thegr81's Avatar
It maybe a vaccum problem, with your 4wd I would check all your vaccum lines going to your transfer case!!
Old Jan 29, 2008 | 09:05 AM
4LO will typically thump/clunk in due to the gear ratio change. That sounds normal.
What do the dash lights do when you are attempting to engage 4HI? If you have Auto4wd, try running through the OBD2 Non-Automatic Transfer Case Diagnostics and let us know what the outcome is.
The other thing to check/try is to check/clean the electrical connections at the switch (in dash), TCCM (transfer case control module - behind the passenger side kick panel), and at the encoder motor (on the transfer case). We have had some members that had similar problems and it was a loose connection at the switch. Others have had corrosion issues at the connector on the TCCM.
Hope this helps!
seriosbrad
Nov 7, 2015 09:08 PM
tim244x4
Sep 3, 2009 11:07 PM
PiTRiFF
Jan 28, 2009 09:36 AM
hamoni1
Dec 6, 2005 07:39 PM
tambo
Mar 4, 2005 05:44 PM
