Front 4x4 suspension
Old Mar 14, 2008 | 09:59 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default Front 4x4 suspension
Ok I know the '97 Bravada has no front springs per say as far as coil or leaf, but is there some other system on the frontend that performs this function or do the shocks just take the brunt?
Old Mar 14, 2008 | 10:03 PM
Default RE: Front 4x4 suspension
The front of all 4wd & awd s-series vehicles is a torsion bar setup. The bar runs from the lower control arm back to a cross member. The resistance to twisting is what gives the front end the spring rate necessary.
Old Mar 14, 2008 | 10:04 PM
portcqb's Avatar
Is this something that commonly needs replacing in late '90's models and if so at what mileage?
Old Mar 14, 2008 | 10:06 PM
Unless you are having problems with the front end sagging and cannot correct it by tightening the torsion jack bolt, you don't have to worry about replacing them.
Old Mar 14, 2008 | 10:09 PM
portcqb's Avatar
Ok thanks
Old Mar 14, 2008 | 10:10 PM
No problem!
Rottidog
Jan 26, 2010 07:37 PM
shawn
Mar 22, 2009 05:58 PM
Marcin
Suspension Tech
Jan 25, 2007 06:08 PM
cimbali
Jun 30, 2006 05:07 PM
95chevyflames
Suspension Tech
May 8, 2005 07:20 PM
