front axle size?
Old Feb 22, 2008 | 04:01 PM
99 Blazer 4 door's Avatar
99 Blazer 4 door is an unknown quantity at this point
Default front axle size?
do we have a front axle on the 99 blazers called a 7.2 I.F.S and if we dont what is our front 4x4 assmbley called and wht gears do we have up front?
Old Feb 22, 2008 | 07:06 PM
Default RE: front axle size?
It is an AAM 725 IFS. It is a 7.25" diameter ring gear.
Your current gears will be the same as the rear end ratio as specified on your RPO sticker in the glove box.
For a complete list of RPO code definitions, CLICK HERE.
Old Feb 25, 2008 | 08:44 PM
Thanks. I want to put new lower gears in my blazer but i was wondering sence i have 4 wheel drive do i also have to put lower matching gears in my front end? Or if i do put them in will it mess up something if i dont have them matching front and back?
Old Feb 25, 2008 | 08:48 PM
If you ever want to use the 4wd again, you have to have matching ratios in both the front and rear diffs.
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
98Blazer
Feb 15, 2006 05:40 PM
