front axle vacuum actuator
Old Feb 2, 2012 | 09:56 AM
Paul Burke's Avatar
Paul Burke is on a distinguished road
Default front axle vacuum actuator
Does the actuator get vacuum in 2wheel or 4wheel? Mine is pulling in when in2wheel.
Old Feb 2, 2012 | 12:43 PM
Thogert's Avatar
It's supposed to only get it in 4.
Old Feb 3, 2012 | 01:03 AM
neo71665's Avatar
You either have a bad vac switch on the t_case or somebody has the hoses swapped around.
Old Feb 4, 2012 | 10:20 AM
stanitis's Avatar
stanitis is on a distinguished road
When I bought My JIMMY in '07, the 4X4 didn't engage so I searched & found that the vacuum line cluster on top of the trans/tc was not put on in the right spot. There is a small hole in the rubber vacuum cluster that lines up & goes onto that connection, that "connection" has a long skinny plastic stem that the vacuum line cluster slips over. Hope that helps & your problem is that simple too! BTW, it is very hard to see what You are looking @ up in there. It is best done on a rack!
babeba67
Mar 21, 2015 08:31 PM
jnail
Jan 5, 2013 01:55 AM
a2dadamm
Nov 19, 2012 08:44 AM
Cassera
Jul 18, 2012 09:04 PM
19jimmy99
May 2, 2009 08:42 PM
