Front CV joint 92 full-size
Old Apr 30, 2010 | 03:48 AM
rocketrich67@aol.com's Avatar
rocketrich67@aol.com is on a distinguished road
Default Front CV joint 92 full-size
Need to replace front cv, have done it on a front wheel-drive car before. Is it done the same way or is there anything else I should know. Thanks for any advice.
Old Apr 30, 2010 | 06:39 AM
It's pretty much the same. You may have to remove the hub/bearing assembly from the steering knuckle to be able to get enough room to remove the CV shaft, but then again, you may have a flanged connection at the diff which may allow you to turn the wheel all the way in one direction and pop the CV shaft out without removing much of anything else.
admathi
Dec 15, 2019 04:24 PM
josemateos
Feb 18, 2014 10:00 AM
Guntheone
Dec 4, 2010 05:59 PM
goerzenl
Nov 1, 2010 10:14 PM
dsrtdon
Jan 8, 2010 04:01 AM
