Front Diff Help
Old Dec 3, 2016 | 01:53 PM
jdcool4's Avatar
jdcool4 is an unknown quantity at this point
Default Front Diff Help
I was replaceing my left half shaft under warranty. When i put the exchanged half shaft in at first it wouldnt go then with a little wiggleing and twisting it goes all at once . No hammering or forceing. Go and put the bearing on it wont fit. Come to find out they gave me a ford half shaft that goes in deeper and wont come out. I am thinking that the snap ring expanded on the far side of the gear on the inside.
Dose any one have any ideas i took the bolts for the side cover off (left side by the way) and nothing what will it take to pull the left side cover half shaft gear and all so i can get to the clip to compress it
Old Dec 6, 2016 | 01:16 PM
El_Beautor's Avatar
Normally when removing the half-shaft the easiest way to get the clip to release is to put a chunk of wood (short length of 2x4 works great) against the half-shaft and then hit the wood with a hammer. This is usually enough to pop it out. Good luck.
00blazer13
Sep 29, 2011 08:25 PM
jakem
Apr 22, 2011 12:34 AM
tofunater
Jan 14, 2011 08:11 PM
FireRed2000
Oct 14, 2010 01:37 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
