front diff proplems
Old Dec 12, 2012 | 06:53 AM
turple27's Avatar
turple27 is on a distinguished road
Default front diff proplems
i can put my blazer in 4wd hi or lo and the TC is engaging and the front driveshaft is spinning but the cv axles arent moving, it looks like the gear oil leaked out both sides of the diff, i was wondering if that the diff was too low on gear oil it would stop it from engaging when you turned on your 4wd. it was working perfectly the day before and then just wouldnt work this morning to pull my self out of my drive way. anyone know what it could be
Old Dec 12, 2012 | 11:39 AM
Diaita's Avatar
low gear oil shouldn't cause the front dif not to engage. it's probably the actuator for it has an issue.
Old Dec 12, 2012 | 02:42 PM
turple27's Avatar
ok just wasnt sure because, it has some kind of sensor or some **** beside the vacuum line
Old Dec 12, 2012 | 06:05 PM
xgiovannix12's Avatar
low oil wouldn't give you a front diffy lock issue. Its either a bad vac line or a bad actuator .
Being low on oil would be an issue when its locked... IT can cause damage to the gears.
flipzat
Jan 24, 2011 11:47 AM
dagda
Jan 12, 2010 06:37 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
fla_blazer4x4
Jun 12, 2008 07:29 AM
slayer6x6
Dec 8, 2005 02:24 PM
