Front differential problem
Old May 19, 2012 | 01:57 PM
Longer02's Avatar
Longer02 is an unknown quantity at this point
Default Front differential problem
I have what I think is a front diff problem. I was driving the Blazer today and all of the sudden I hear this terrible grinding/humming coming from the front end. Then all of the sudden the tach goes to zero so I thought the truck died. I put it in neutral and tried to start it and it was still running. The speedometer was still sitting at 60 mph, which was the speed I was going when this all happened and none of the other gauges were responding.
So I get the truck off the side of the road, look it over and see nothing out of the ordinary. I start it up, starts fine, shifts fine, etc., but it has the grinding noise like no other when the speed gets over what I am guessing is 5 mph. Don't seem to notice it in reverse at all either.
So my questions are, does this sound like the front diff taking a dump? Why would the gauges stop working? Also, the 4wd does not work either. I am so sick of this thing, when I finally get it fixed I am getting rid of it. Any help is greatly appreciated. Thank you.
Old May 19, 2012 | 05:54 PM
war00's Avatar
war00 is on a distinguished road
dont know about your gauges, but the grinding noise could be a wheel bearing. jack it up and check for play and if thats fine than check the front diff oil for metal shavings.
Old May 20, 2012 | 10:57 AM
Longer02's Avatar
Thanks for the suggestion. I know it's not a wheel bearing though. I had just replaced the passenger side wheel bearing and this sound is totally different than when a wheel bearing is going out. I will hopefully be able to get it back to my house today to start checking it over good.
Drew4711
Oct 6, 2012 12:47 PM
kmalysa
Aug 17, 2009 08:43 PM
SanfordBlazer
Mar 2, 2009 06:37 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
dion21379
Mar 24, 2006 03:17 PM
