front drive shaft slop
Old Aug 7, 2016 | 07:29 PM
welb's Avatar
welb is on a distinguished road
Default front drive shaft slop
hi all,2000 blazer 4x4,4 button auto t/case,weird scraping sound on initial acceleration.i believe its the sloppy cv joint on front drive shaft.this noise happens in 2wd but i believe this shaft is always live.am i correct in that thinking and can i run without the front shaft?thanks
Old Aug 8, 2016 | 11:18 AM
slimsummers's Avatar
slimsummers is on a distinguished road
If you are in 2wd (not auto on the 4 button panel) then the front shaft is not engaged on either end and should not be turning. Removing it will not be an issue, except you no longer have 4 wheel drive of course. But if it is making the noise in 2wd then it is not likely the driveshaft causing it. Your CV joints on the axles could be causing it, a bent dustcover on the brakes contacting the rotor, etc.
Old Aug 8, 2016 | 01:45 PM
welb's Avatar
just got under there.defenitely turning in 2wd
Old Aug 8, 2016 | 04:25 PM
Some of the auto transfer cases have a slight engagement of the clutch even when in 2WD, yours may be one of them. In any event, pulling the shaft will not cause any issues except no 4X4.
Old Aug 8, 2016 | 05:02 PM
welb's Avatar
ya,just pulled it.yet to drive and find out if noise is still there.
regardless,dont need 4x4 anyway.2wd now,less things to clink and clunck and clank.thanks for the input
nbguide
Sep 24, 2023 12:52 AM
nbguide
Jun 22, 2013 05:28 PM
PMeloy
May 10, 2011 03:37 PM
lizzj70
Jun 23, 2010 06:57 PM
Jeremy_87_S10
May 28, 2006 09:02 PM
