Front end clunk when turning
Old Aug 9, 2016 | 04:26 PM
Jalmquist125's Avatar
Jalmquist125 is on a distinguished road
Default Front end clunk when turning
2000 chevy blazer lt 4x4. I'm getting a clunking noise from the front end when I steer in either direction. It happens at lower speeds mostly but sometimes at moderate speeds. It seems to happen mostly when I turn a bit more agressively or quickly but even under those conditions it doesn't happen every time. Hopefully this is enough info, any ideas?
Old Aug 9, 2016 | 07:09 PM
slimsummers's Avatar
slimsummers is on a distinguished road
If the clunking is continuous while moving I would say most likely is a bad CV joint on an axle(s). If it is just a single clunk it could be a worn out ball joint or part of the steering linkage.
Old Aug 9, 2016 | 07:27 PM
It is just a single clunk only when I turn
Old Aug 10, 2016 | 11:33 AM
Could still be an axle, but more likely you have something like a ball joint worn out and it is shifting with a clunk when you turn. You'll need to get the front end up on jackstands and start trying to move things with a prybar until you find the loose component.
Old Aug 10, 2016 | 11:47 AM
newguy's Avatar
And dont drive it!
AndrewO1991
16
May 30, 2012 09:27 AM
choover82
Jan 14, 2012 01:02 PM
vankuen
Mar 24, 2008 09:24 AM
Wxman2000
Aug 11, 2007 03:48 PM
raviz
Nov 21, 2006 09:54 AM
