Front End Pop
Old Aug 20, 2012 | 06:46 PM
  #31
I've looked for aftermarket torsion bar mounts at several parts places and web sites and can't find anyone that has them... hate to go to the dealer... they probably want a fortune for them. They look very similar the the rear sway bar end links, but are considerably shorter. IIRC they mount to the frame and the crossmember. When they're bad, typically they pound like hell on the floor right below the seat when you go over bumps in the road. Just a thought, might want to check them.
Old Aug 20, 2012 | 10:52 PM
  #32
Rottidog's Avatar
Anyone look at the hub bearing assembly? I mean if you're turning & going forward & hear a pop, they'd be suspect to me.
Try doing it slow & have a friend stand beside the truck listening to one side then the other. At least that way you'll know what side it's from & possibly front or back etc.
Old Aug 21, 2012 | 10:00 AM
  #33
stokedboss's Avatar
stokedboss is on a distinguished road
@Captain Hook; They don't seem to make noise going over bumps, just when turning. Could it still be the torsion bar mounts?
@Rottidog; how would you check the hub bearing assembly?
Old Aug 21, 2012 | 12:07 PM
  #34
Rottidog's Avatar
I'd lift the front end, put it on blocks & look at the boots for grease leaking, make sure the metal band that holds the boot on is still there.
Rotate the tire listen & feel for any grinding or roughness. Try wiggling it & look for movement.
Old Sep 4, 2012 | 07:36 PM
  #35
stokedboss's Avatar
I took a look at the hub bearing assembly. The boots look pristine, all of the metal bands are in place, I grabbed the hub and rotated while pulling/pushing on it, and it didn't seem to make any abnormal noise. It all seems to be tight.
BoDog89
Nov 29, 2012 07:11 PM
Blade_24k
Jul 23, 2012 08:22 PM
kyjonesy
Feb 25, 2011 08:35 PM
Wxman2000
Aug 11, 2007 03:48 PM
ShadowHawk
Suspension Tech
Feb 11, 2007 09:50 AM
