Front End/Rear End
Old Oct 24, 2013 | 10:11 PM
doktornasty's Avatar
doktornasty is on a distinguished road
Default Front End/Rear End
I know someone has probably asked the question before but I could not find the response. Here is the rundown:
I just bought an 87 K5 as a project truck for my daughter and I to work on. The front and rear end are geared differently. I would like to do swap out one or the other, what resources can I use to reference the repair? Is there generally a preference to which I would switch? The truck will be for her upon completion and may do some light off road work but nothing too crazy (South Texas is flat as a pancake).
It is our first build, but I have a decent amount of tools, patience and time...not to mention I am mechanically inclined.
Thanks in advance!
Old Oct 24, 2013 | 10:25 PM
chris015's Avatar
Id do the rear before the front if it was me. For now you need to find out what gear ratio either one is.
google " gear ratio counting teeth" and read into how to figure it out.
There should be a sticker in the glove box,or somewhere. it has a bunch of 3 letter/digit codes on it. find any of em that has the first letter g. itll be like gu1,gu2,gu3 etc. post back. Problem is its hard to tell which of the 2 diffs has been swapped unless you can tell by worn nuts,bolts,and gouges. etc
Old Oct 25, 2013 | 02:04 AM
Diaita's Avatar
Agreed, rear axle is easier. I would chose the lowest geared, and replace the other.
Old Nov 2, 2013 | 07:58 PM
The code in the glove box reads GU6.
Old Nov 2, 2013 | 08:25 PM
newguy's Avatar
Old Nov 3, 2013 | 03:12 AM
chris015's Avatar
yep 3.42,if you have "g80" beside it you also have a locking diff,it was a option.
BLAZER97LS
Apr 16, 2012 02:56 PM
trukker
Jun 13, 2011 07:03 AM
brino1
Feb 25, 2011 08:05 PM
ligero18
Nov 4, 2009 12:38 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
