Front end work
Two questions, need advice.
I need to replace the lower ball joints on my 96 Blazer 4x4, 130,000 miles, so it will pass inspection. Since the bottoms are getting replaced and I'll be going through a lot of work, I will do the upper joints too. I've seen in previous posts Moog is a recommended brand, any thoughts on NAPA brand or others?
Second question refers to the ABS light staying on. There are no codes telling me why it is on. I was figuring the brake unit is out or a sensor but then while searching posts for ball joints, I read about the hubs causing the light to come on. Anyway to tell if the hubs have gone bad before I replace the hubs or are there other reasons for the ABS light?
Thanks in advance.
Thanks in advance.
If the abs lights is on for an acutal reason and not just a short at the light it should have stored code. As for the balljoints I have the Napa ones for my lowers and I have Spicer Professionals for the uppers,they make the Napa ones.
ComputerNerdBD
06-24-2009 10:33 PM
