Front Hub Assembly
Old Mar 12, 2014 | 04:10 PM
slickracer34's Avatar
slickracer34 is on a distinguished road
Default Front Hub Assembly
Hello. I'm new to this so bear with me. Does anybody know if any other GM truck front hub assy will bolt up to my '99 Jimmy? The reason being is I want to change the bolt pattern without using spacers. I have spacers on the rear now and can get ones to change the bolt pattern but I don't want to widen the front stance any. A different bolt pattern will greatly improve my options for aftermarket rims.
Old Mar 12, 2014 | 05:19 PM
El_Beautor's Avatar
As far as I know there are none that will bolt up directly. It MAY be possible to swap to something like the Canyon/Colorado if you changed the whole front assembly including the spindle, rotor, brakes, and hub. I don't know if this is possible, but if you could find one at a wrecker you could start measuring and comparing to see if the swap is possible.
Ren1914
Apr 2, 2015 07:56 PM
cbur307736
May 5, 2011 07:27 AM
strad
Dec 11, 2010 08:04 PM
Marcin
Apr 13, 2007 01:09 AM
greengoose89
Aug 3, 2006 07:32 AM
