Front rubber suspension stopper
Old Oct 9, 2013 | 03:05 PM
Scottcmb's Avatar
Scottcmb is on a distinguished road
Default Front rubber suspension stopper
Hi Guys, I have a 2002 4.3 blazer. The rubber suspension stopper on the front right hand side needs to be replaced. Any one out there know how to remove it?
Cheers Scotty
Old Oct 9, 2013 | 06:10 PM
abig84's Avatar
pretty sure its just one nut you have to take off. doubt it will be that simple as its probably rusted to heck. ive replaced them on 70s cars which is basically the same kinda set up
Old Oct 9, 2013 | 09:01 PM
TheDirtyDime's Avatar
TheDirtyDime is on a distinguished road
I second that its just one nut i believe, they are a pain to remove sometimes, but if you need to just cut the nut real carefull with a sawzaw then use a wire brush to clean off the rust from the bolt. I am not sure if the bolt can be removed or if it is attached but you could always just cuz the bolt then drill a new hole and put in a new bolt.
spatula6554
Apr 10, 2012 02:17 PM
shawn
Mar 22, 2009 05:58 PM
sktdarkstar8
Aug 15, 2006 10:26 PM
Phre4k
Jun 2, 2006 02:40 AM
evan_j
Tires and Wheels
Oct 3, 2005 04:52 PM
