front suspension and steering
Old May 10, 2012 | 01:27 PM
SOB1999JIMMY's Avatar
SOB1999JIMMY is on a distinguished road
Default front suspension and steering
Got all my parts but a little intimated to dive right in any one done idler pittman arms tierods sway bar links and ball joints
Old May 10, 2012 | 04:19 PM
aa21830's Avatar
aa21830 is on a distinguished road
Think maybe a couple of us have done some of that...start here with the ball joints:
https://blazerforum.com/forum/tech-a...acement-27627/
Old May 10, 2012 | 06:41 PM
50lb_cat's Avatar
If you have air tools its very easy, if not... hope you are patient lol.
Old May 12, 2012 | 10:37 PM
wild bill's Avatar
wild bill is on a distinguished road
Did my front end last year. Hardest part for me was separating the pitman arm from the steering linkage. Real PIA
Old May 12, 2012 | 11:01 PM
Rottidog's Avatar
Get a tie rod fork for starters. Spray the nuts etc a few days ahead of time with PB Blaster or w/e you have on hand, SeaFoam Creep works well for me. In a 2nd gen blazer/jimmy you'll probably have to loosen or remove the steering box bolts & lift the box to remove the pitman. Again - soak everything in a good penitrant a couple days ahead of time & every day up to the day of the work... you'll thank me later lol.
Old May 13, 2012 | 08:33 PM
DON'T use a pickle fork to separate the pitman arm from the relay rod, (center link, drag link, whatever). If you hammer on it, damage WILL be done to the gear box. Gotta use a special puller, there's plenty of room under there, and it's a snap with the right tool. Gear box MUST be removed on 4WD to replace the pitman arm, ain't no 2 ways about it. Another special puller is necessary to remove the pitman arm from the gear box. 185 foot pounds of torque when installing the new pitman arm onto the gear box. Idler arm is a piece of cake. Use the same puller as separating the pitman arm from the relay rod. When installing, make sure relay rod is within 1/16" of level or you'll have bump steer. It is adjusted by moving the idler arm up or down before tightening it up to the frame. Wheels straight ahead, measure from the center of the inner tie rod stud up to the frame on both sides. If I remember right, it's in the ballpark of 2 1/4".
Air tools make the job a lot easier and faster, but it's still a messy job.
Old Jun 2, 2012 | 10:31 PM
Got the idler and Pittman arm done had to customize my pullerto get it on the idler arm had every thing done andwas hooking up the steering gear and I missed the hole on the back side I bent the whit out of it and thought I was screwed but I cut the rivets out seperated the rag joint straighented it in my vice pulled the steering gear lined it up replaced therivets with bolts and locking nuts and a little loctite for good measure after all that I got a little pissed at my truck go figure still have not got the rest donebut I got my parts laying around for when I get to it
Old Jun 2, 2012 | 10:33 PM
Dont own a single air tool but I want em badd
tracedumashsog
Jul 19, 2014 01:04 PM
jaydon44
Jan 18, 2012 03:35 PM
lombard
Jan 26, 2011 01:49 PM
mxboy96
Jan 1, 2010 09:08 PM
Marcin
Suspension Tech
Jan 25, 2007 06:08 PM
