Front wheel bearing....
Old Nov 20, 2009 | 12:40 PM
tdannar's Avatar
tdannar is an unknown quantity at this point
Default Front wheel bearing....
1998 4X4
Getting a fairly loud whirrrrrrrr when going straight or turning right. When I turn to the left, the noise stops. Noise is not real noticeable until over 30mph. The noise seems to be coming from the right front.... By this can you figure out if it is the left or right wheel bearing (assuming that is what it is...). Hate to replace wrong one....
Thanks!
Old Nov 20, 2009 | 02:51 PM
CNYCountryKidd's Avatar
CNYCountryKidd is on a distinguished road
Replace the side it whirs from
Old Nov 20, 2009 | 07:00 PM
02BlazerS.jersey's Avatar
02BlazerS.jersey is an unknown quantity at this point
Thinking that if your turning right there is pressure off of left tire so noise still there...if turning left pressure is on that tire (and bearing) so maybe that's the side its bad????? Did you try jacking it up and spinning each tire and see if you can hear anything?
Old Nov 21, 2009 | 02:37 PM
Sounds like a driver side wheel bearing failure.
Old Nov 21, 2009 | 08:32 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
I usually try to replace both sides at the same time. What ever caused the first to go bad, usually happened to both sides. As a result, it's just a matter of time.
Old Dec 6, 2009 | 10:09 PM
tdannar's Avatar
Default Finished!
When I took things apart, the drivers side was more noticeable than the passenger, but like advised, I just replaced both. Now smooth and quiet!
brianp
Jun 1, 2020 10:30 AM
ComputerNerdBD
Aug 30, 2011 10:59 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
F6_Sno_Pro
Nov 8, 2005 01:02 AM
h123hop
Aug 13, 2005 08:45 PM
