Front wheel travel questons
Old Oct 21, 2012 | 01:32 PM
seanmurphy265's Avatar
seanmurphy265 is on a distinguished road
Default Front wheel travel questons
I have a 1992 s10 4x4 with 1" of lift cranked into the front torsion bars. I have 2" shackles on the back with rough country helper springs. I also replaced the 4 collapsed shocks with rough country shocks. A week ago I was hunting and as I was checking out of the wildlife refuge the left front upper ball joint came out of the spindle mount. I replace the upper and lower ball joints when I did the lift.
The upper ball joint pulled the nut off, broke the cotter pin, and came out. I was creeping along because I was stopping. I got a new upper ball joint and put it all back together. Not understanding what happened I leaned out of the window as I was going across some bumps. The tire is moving up and out of the wheel well. I thought it was suppose to move up and to the inside of the wheel well?
Both front tires had positive camber so I adjusted on the eccentric bolts on the control arms. I am now at -1 (slightly leaning in to the wheel well). This helped some with the wheel travel, but the wheels are still moving up and out.
I'm not sure what I need to do? Is this normal?
ethan.zick
Apr 27, 2010 08:49 PM
Spectreblazer
Feb 25, 2010 12:09 PM
king22
Suspension Tech
Sep 25, 2009 04:20 PM
Patrick_Boyle
Apr 6, 2009 08:43 PM
painter
Jun 24, 2007 04:41 PM
