gear ratios
Old Feb 6, 2014 | 06:19 PM
rexmburns's Avatar
Super Moderator
Do a search on it lots of details about it on here
Old Feb 6, 2014 | 07:03 PM
kcurry02's Avatar
kcurry02 is on a distinguished road
ok will do thanks
Old Feb 9, 2014 | 07:55 AM
okiedoak20's Avatar
Kcurry.... I have a rear set of 4:56 gears, not installed yet
And im an starting to worry about the RPM thing at hwy
Speed...according to a gear chart Im looking at it is
saying 4:56 with 33" tires 3000 Rpm's....but at what speed
And is that also including the transmission lock-up...
Currently im running 3:73 gears with 33" tires and gas milage
Is 12.6mpg hwy....a lot less in 4wd ...and in the 10's if I run in
The city.....I took Diatia's suggestion and took in all the factors
Weight, lift , tire size and weight, rotatioal mass..etc...
Im starting to over think this and worry....I cant return a usrd gear
Set and installation and set is not cheap...so I need to be right
The first time....
Old Feb 10, 2014 | 10:33 AM
El_Beautor's Avatar
The first time....
Well if you find that the 4.56 gears are too low for the 33" tires you'll just have to move up to 35's.
Old Feb 10, 2014 | 06:26 PM
okiedoak20's Avatar
El.... LOL...you know i was just thinking that,,, so i guess it could be a win win either way
Old Feb 10, 2014 | 10:46 PM
LeWhite's Avatar
Think 8 mpg city. With gas at $2.76 per gallon it aint so bad!
Old Feb 11, 2014 | 02:44 AM
Diaita's Avatar
My last wheeling trip out of town a couple days ago I filled up before I left, and filled up when I got home just to see where I'm at, and for everyone's benefit here.
I used 10.9 gallons of fuel for 117.5 miles for 10.78mpg(converted for my us friends).
Of that:
-about 35 miles of semi-flat freeway at 75mph,
-about 55 miles of winding, mountainous highway at about 55mph
-about 20 miles of mountainous forestry roads
The rest was a few hours off-roading at 10mph or less through terrain a mildly lifted Blazer just wouldn't make it through.
On the highway and freeway, it still won't stay in overdrive all the time, and climbing through mountains I still put it in D so it won't hunt gears. If I were to re-gear again, I would seriously consider 5.29s in my case... $.02
Old Feb 11, 2014 | 07:34 PM
gitch93's Avatar
gitch93 is on a distinguished road
so I am in a spot I wanna do the 4.10 gear ratio I run 3.43 atm with a 7.6 rear end. I just purchased a np233c for my 4 door jimmy and having it over hauled. what axles or vehicles carry a 8.5 rear end with 4.10 gear ratio
Old Feb 11, 2014 | 11:38 PM
Diaita's Avatar
Look for a front dif from a late 70s, early 80s GM 3/4 ton truck. 8.5" 4.10 were pretty common. If you're looking for a bolt in assy, I don't think they exist in 4.10.
Old Feb 12, 2014 | 09:37 AM
El_Beautor's Avatar
Like Diaita said, I don't think you'll find a S-series 8.5" rear end with 4.10 gears stock. As far as I've ever been able to find anywhere, the only S-series trucks that came with 4.10 gears were the 2wd pickups with 4 cylendar engines. I don't think any S-series 4x4's came from factory with 4.10 gears.
GryphonBlaze
Dec 30, 2011 09:33 PM
jamies96
Mar 6, 2011 12:17 PM
Tony H
16
Jul 30, 2010 09:26 AM
Boyer2011
Feb 28, 2009 10:20 AM
ababion
Mar 14, 2008 01:07 AM
