greasing stock lower ball joint
Old May 17, 2009 | 12:33 PM
blazinloud's Avatar
Lightbulb greasing stock lower ball joint
narrowed my insane sqeak to the drivers lower ball joint, im pretty sure its just dry.
anyone know if there actually is a grease nipple for this? i searched and searched and found nothing
and if there isnt are there any alternatives other than changing it? soak it in some wd-40? lol
are they tough to replace?
Old May 17, 2009 | 05:30 PM
There should be. It may be covered with dirt and old grease down through the hole in the lower control arm.
Old May 17, 2009 | 08:28 PM
oisinirish's Avatar
Did the stock ball joints come as serviceable units? If not you could use a grease needle to get under the boot and get grease in that way.
Old May 17, 2009 | 08:39 PM
Biohazed's Avatar
if there is no grease fitting, you can go and get a great injector, it looks like a large syringe needle with a grease fitting on the end. There is 2 ways to use this if there is a small hole in the ball joint then you can inject the grease into there if not then you can inject it directly into the boot
Old May 18, 2009 | 06:08 PM
blazinloud's Avatar
sounds difficult....kinda.....ball joints have boots? i called and a ball joint was under $30 for the cheapest one.....
Old May 18, 2009 | 07:04 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
You really don't want the cheapest one. You want Moog...
Old May 19, 2009 | 01:57 PM
blazinloud's Avatar
well sure. but my bank account says otherwise at the moment.
Old May 19, 2009 | 07:19 PM
Would your bank account like to pay to have it replaced again in short order?
Old May 20, 2009 | 12:07 PM
AJBert's Avatar
Ummmm...you do realize that you should have been greasing your front end, including all ball joints, as part of regular maintenance, right? I lube my front end every time I change my oil.
Old May 21, 2009 | 12:10 PM
blazinloud's Avatar
ummmm...you do realize i DO NOT CHANGE MY OWN OIL, but thanks for asking.
i really dont think there are grease nipples for this particular ball joint(stock 98) lower drivers side to be exact. i think it was the TRW ball joint they were speaking of....
