Grinding noise under heavy acceleration.
Old Sep 10, 2015 | 01:49 PM
jackm's Avatar
jackm is on a distinguished road
Default Grinding noise under heavy acceleration.
OK thought I might ask here been trying to figure out a problem I'm having. If I am driving normal everything operates perfectly but if I try to accelerate hard I get a gear grinding noise from either the trans or the transfer case. It does it whether its in two wheel or four wheel drive so I am pretty sure its not the rear end. again as soon as I let off the gas and not hit it hard it sound normal. Anyone seen this before?
Old Sep 15, 2015 | 11:54 AM
jackm's Avatar
ok I guess no one has ran into this so I will keep this updated I am beginning to think it might be the torque conveter, hook a heavy trailer up and it does it a lot quicker. any clues on how to check it? fluid for trans is clean.
Old Sep 16, 2015 | 12:53 AM
Rusty Nuts's Avatar
It couldn't hurt to check for a broken motor mount or transmission mount.
Old Sep 16, 2015 | 09:55 AM
jackm's Avatar
Thanks I will have to check for that as well, nice to see someone from Michigan!
Old Sep 16, 2015 | 07:51 PM
odat's Avatar
I don't know what xfer case you have but it sounds like yours has the internal chain and it is stretched and is skipping teeth under load
Old Sep 17, 2015 | 02:58 PM
jackm's Avatar
The transfer case I believe is a NP236 I was thinking that but would it happen both in two and four wheel drive, wouldn't the chain just slip in four wheel drive not two wheel?
Old Sep 19, 2015 | 09:07 PM
Trelane's Avatar
Trelane is on a distinguished road
I'd take a good look at the u joints, look for excess grease on the floor pan or rust on the u joints. Next check your fluid levels trans,t-case rear end. Then look for leakage at the rear wheels, could be a bad bearing.These noises can be a pain to diagnose, I recently changed the left rear bearing and was convinced the noise was coming from the right front.
Old Oct 2, 2017 | 09:51 PM
Edvalle10's Avatar
Edvalle10 is on a distinguished road
Default Same issue
wondering if u ever found out the issue? Sounds like the same issue i have. Except my t-case got rebuilt thinking that was the problem and its still making that noise.
ckroll98
Aug 29, 2013 09:51 AM
deez283
Feb 27, 2012 08:36 AM
madcow
Apr 20, 2010 01:02 AM
GMJimmy
Jan 27, 2010 05:52 AM
shitbox
Aug 23, 2005 11:35 AM
