Help with steering dampener 94 Blazer
Old Dec 30, 2018 | 05:11 PM
Wiytboi's Avatar
Wiytboi is on a distinguished road
Default Help with steering dampener 94 Blazer
Hay so I'm trying to install a Steering dampener on my 94 blazer. its got 4in. lift, 35in tires but i couldn't tell you which lift kit it was. and i cant seem to find any info or pics on where or how to attach dampener. so i found this forum instead.. if ya could post any pics of your 94 blazer and how you went about mounting the a dampener that would be great along with any info that could be useful to me would be appreciated also. Thanks
Also after cruising this forum I'm aware of the issue of slop in steering, which is half the reason I'm trying to install a dampener, so i will be looking into finding the slop in the steering see if its maybe a back part also.
Old Dec 30, 2018 | 05:16 PM
If you can post some pictures of the lift components, I'm sure people would be able to help. For starters, the Rough Country 2.5" lift kit has tubular upper control arms.
As for the damper, that will not take slop out of the steering and instead just dampen any shocks to the components. I will be doing a small adjustment to my steering gear in a bit but to do it properly, I'll be disconnecting the damper I had installed recently.
Old Dec 30, 2018 | 07:28 PM
cleburne red's Avatar
I've got a dampener on mine as part of the rough country 6 inch lift. Not sure how much different that is from your 94, mine is a 95.
​​​​​​I've got some pics in my thread in the off roading section. Let me know if you need any more
95BlazenLT
Lifting Tech
Feb 7, 2013 09:03 PM
sharrard.
Lifting Tech
Apr 22, 2011 10:13 AM
thedopeshow912
Lifting Tech
Jul 4, 2009 08:19 AM
dalifts
Feb 17, 2009 11:12 AM
akcalvin
Lifting Tech
Oct 21, 2008 07:15 PM
