Helper (or repair) Bearings
Old Oct 1, 2014 | 10:19 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
Default Helper (or repair) Bearings
The other day we discovered that the driver side axle shaft had worn a spot in it where the oem bearings were. Apparently these bearings are made to shift the bearings to a new position where the axle isn't worn. Has anyone used them or heard any bad stories about them? We really don't have the money to replace an axle shaft right now but I would rather not use these if they are unsafe.
Old Oct 2, 2014 | 05:02 PM
rexazz2's Avatar
As long as its a reputable bearing manufacturer I would not be afraid to use it .
Take a look at the surface the seal is going to ride on because it may be damaged as well
Usually those bearings are more expensive , thats money you could be putting towards another axle
dano440
Suspension Tech
Mar 28, 2012 12:26 PM
team prodigy james
Aug 13, 2010 06:45 AM
86 like me
Sep 23, 2008 05:57 PM
tyson0016
Oct 30, 2007 04:41 PM
kelraes
Sep 21, 2007 03:10 PM
