How can i find out if i got sagging torsion bars ?
Old Aug 3, 2011 | 04:11 PM
xgiovannix12's Avatar
Default How can i find out if i got sagging torsion bars ?
Well I'm going to be installing my shackles and be doing my 1.5 inch tbar crank . How can i find out if i got sagging torsion bars ?
I dont wanna crank them then my 31 inch tires are gonna rub
is there a way to see if there sagging? the truck rides great and the bolts are even with the cross member.
also this is for my 1992 s10 blazer Edit: The truck has 137k miles on her
Thanks for reading
Old Aug 3, 2011 | 06:03 PM
Hightec1's Avatar
Hightec1 is on a distinguished road
I never heard of a torsion bar sagging? If the blazer is sagging or not level it could be a broken leaf or rotted/broken rear shackle.When i adjust torsion bars i count how many turns then mark it on the cross member in case i need to turn them back.If the blazer is level you can measure each fender/quarter panel in the center to ground to see where your starting from.Measure it before and after to see how much you lifted it.
Old Aug 3, 2011 | 06:16 PM
Torsion bars definitely can weaken. Typically it is the passenger side that does it more often and that is likely due to the heat from the exhaust/catalytic converter.
About the only way to tell is if your adjusting bolts are almost all the way in.
Old Aug 3, 2011 | 06:47 PM
i dont think there all the way in but thanks
i know the heads are even with the cross member
Old Aug 3, 2011 | 07:00 PM
weazel's Avatar
weazel is on a distinguished road
Mine were definetly weak. I had front suspension that rode like a 70's boat down the road. Very weird to drive and what not. It took me replacing almost every suspension piece on the front end figure it out. Really sucked to put money into it like that!!
Old Aug 3, 2011 | 07:07 PM
were your torsion bolt heads even with the cross member ?
my truck looks level and also if i put a level on it its on the spot i just hope i don't run into problems cranking them
Old Aug 3, 2011 | 07:57 PM
weazel's Avatar
No, my bolts were slightly lower than the cross member they mount in! I think that each vehicle is different as to what the bolt distance is going to be. I thought my truck also looked level. Looks can be deceiving!!
Old Aug 3, 2011 | 08:10 PM
i guess i need to hope for the best
Edit: also when i do the lift should i start with the tbars ? or the shackles?
Old Aug 3, 2011 | 09:52 PM
mdehoogh's Avatar
Shouldn't make a difference which is done first. tbars will most likely be easier, make sure you set aside time for the shackles because some people have had a pretty hard time getting the shackle bolts out.
Plus 31's will certainly fit in the back, might not be a bad idea to do the tbars first just to make sure the tires fit alright before getting too far along
Old Aug 3, 2011 | 10:11 PM
Yes i know also imma bang them out with a air hammer i shouldnt have much trouble
OH_VDUB
Feb 28, 2012 06:59 AM
Hizapitt
Mar 15, 2010 07:27 PM
98BlazerLT4x4
Oct 28, 2008 08:18 AM
stevenf
Lifting Tech
May 9, 2008 11:38 PM
beeneeb
Dec 7, 2004 05:10 AM
