how to test transfer case vaccuum switch
Old Jun 28, 2008 | 10:15 PM
matclark's Avatar
matclark is an unknown quantity at this point
Default how to test transfer case vaccuum switch
how would you test the transfer case vaccuum switch on a 94 4.3 s-10 blazer ? i need to know,,on the switch itself,,,which one of the 3 comes from the engine,, and which 1 goes to front actuator,,and which 1 is the vent ? i read that you can put this vaccuum plug on wrong,,i have constant vaccuum at the frant axle actuator,,i was thinking the previous owner may have put it on wrong,,,,i boughtmy blazer from a total drunk,,and i dont have a clue at what all he has done. i have fixxed alot of stuff....i do have a hand operated vaccuum pump,,but i dont want to damage the vaccum switch.. please help !!!!
Combining consecutive posts. Please use the edit function if another member has yet to reply. Thanks! TBB
to simplify things...i need a break down of the transfer case vaccuum switch....which one of the 3 nipples does what??
And another...
which 1 of the 3nipples is the vent? the other 2 should be the vaccuum switch,from the engine to the front actuator...
Old Jun 29, 2008 | 11:31 AM
matclark's Avatar
Default RE: how to test transfer case vaccuum switch
Old Jun 29, 2008 | 11:34 AM
matclark's Avatar
Old Jun 29, 2008 | 03:10 PM
burak sozer's Avatar
burak sozer is an unknown quantity at this point
theres 3 vacumhoses comes from TC. One goes directly to switch (should be inder your battery), 2.nd hose goes to vacumsource, directly from manifold or through the canister (ball mounted on the hood) , the 3rd. one is the vent.
if you dont have a vacum leak, you can check your switch if it switches from 2wd to 4wd.
During the years, vacum hoses cracks, I have changed all vacum hoses of mine last month to be safe side.
Old Jun 29, 2008 | 06:45 PM
matclark's Avatar
i know where the hoses come from, for the tc vac switch.....i need to know which one on the vaccuum switch itself, does what,,,onthe switch itself which one is the vent ? which one is the source from engine,,and which goes to the front dif actuator....can any one please help??
Old Jun 30, 2008 | 02:24 AM
Isee, tuesday i ll be able to lift the car or creep under it, gonna check and let you know if its not that late for you.
Flyfishen
Jun 18, 2019 11:22 AM
rich27
Oct 23, 2014 01:08 AM
Barc
Jan 26, 2009 07:07 PM
matclark
Oct 18, 2008 10:14 AM
matclark
Jun 29, 2008 11:29 AM
