howling noise
Old Nov 16, 2007 | 09:08 AM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: howling noise
I went out and bought a wheel bearing last night, my dad is a mechanic at a chrysler dealership so we are going to go threw everything and find this tomorrow. I'm guessing it's the bearing, now along with the howling noise it squeeks like crazy at low speeds.
Old Nov 17, 2007 | 08:02 PM
cliro's Avatar
Put new bearings in (did both.)went for a drive and the noise was still there, put it back on the hoist lubed it all up, went over the whole front end everything checked out fine and took it for another drive, still there. We gave up for the day, i'm just gonna wait for it to get more consistent so it's easier to diagnose where it's coming from.
At least I have 2 shiny new hub assemblies, lol. we even put synthetic in the transfer cases while we had it up.
Old Nov 17, 2007 | 10:04 PM
blazeofglory's Avatar
blazeofglory is an unknown quantity at this point
Just for giggles,how do the sway bar bushings(bar to frame) look. Could be binding slightly, my k5 did that and it was the sway bar bushings. I had replaced the stock rubber bushings with urathane bushings but every so often I have to relube them. Stock rubber bushings don't get lubed per say but if you pull them apart, clean any corrosion off the bar and spray some white lithium lube on them then at least you can rule them out.
Just a thought
Old Nov 17, 2007 | 11:27 PM
cliro's Avatar
we did spray all bushings with lithium grease, no help.
Old Nov 18, 2007 | 01:43 AM
Chevy Lover's Avatar
When you get this noise happening, try putting it in 4WD just to see if there's a change in the sound or if the noise goes away.
Old Nov 29, 2007 | 11:17 PM
cliro's Avatar
ok, we are thinking it's the u-joints now, slight body vibration at 110km(65 for you southern folk) and the noise only seems to happen on acceleration. Sound also seems to be coming from the mid to rear section
Old Dec 10, 2007 | 01:20 PM
cliro's Avatar
FIXED.....was one of the rear dust shields rubbing on the drums.
cwikk
Dec 10, 2013 08:03 PM
Irish07
Oct 31, 2012 06:04 PM
jlm1122
Mar 29, 2010 02:43 PM
Chrismacster
Apr 2, 2009 06:57 PM
Sk8er
Mar 6, 2008 09:43 PM
