humming and whining.
Old Mar 16, 2013 | 08:09 PM
Jdamp32's Avatar
Jdamp32 is on a distinguished road
Default humming and whining.
First time poster. I have a 99 LS 4WD. I have a whirring noise coming from the left front. I can feel it under my feet as well. When I get to about 45 and let off the gas, it whines. My first thought was wheel bearing. So I put it on the lift and checked. No 12-6 movement. Checked the 4wd actuator and its good. Any ideas? Could it possibly be the wheel bearing even with no play??
Old Mar 16, 2013 | 08:11 PM
Jdamp32's Avatar
Also checked front diff fluid. It was super low so I added some, coukd something be wrecked in there causing the noise?
Old Mar 16, 2013 | 08:17 PM
ol' grouch's Avatar
ol' grouch is on a distinguished road
If you think there's a problem with the left front bearing, find a road that curves to the left. If you're traveling at speed and getting the noise, listen to see of the noise changes as you go around a left curve and unload the weight on the L.F. bearing. If the noise goes away, then you probably have a bad bearing or related part. If there is no change, it's probably located somewhere else.
Personally, I'd try the curve an if that doesn't do anything, rotate the front tires to the rear and see of the noise changes location. If the noise now comes from the back, you've got a bum tire.
As for the humming, maybe your Blazer doesn't know the words, and the whining is because it's frustrated because of it.
Old Mar 16, 2013 | 08:32 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
x2 &lol...
Old Mar 16, 2013 | 09:21 PM
bnkk's Avatar
bnkk is an unknown quantity at this point
Pcv valve? Cheap to try. 4wd switch? If you don't mind throwing a little money at it try those things and a hub and new axle ,(rockauto.com) get all that for less then 150_200
javaholic
Mar 10, 2011 06:08 PM
MissTina0301
Dec 18, 2010 03:17 PM
Theresa
May 17, 2010 12:27 AM
schnitzer00
Apr 17, 2007 04:54 AM
schnitzer00
Apr 12, 2007 07:53 PM
