I NEED!!!!! front differential help!!!
So i've been searching everywhere for some help on this and cant find a thing!
about the beginning of last december (2013) the front differential went out (i did check everything i could to make sure that that was the actual problem) so i got a front differential from a salvage yard, pulled out the old one (which was a pain in the a**!) and began installing the one i just got (an even bigger pain) i got it installed (bolts all tight, wiring checked and plugged in right, vacuum line checked and installed, drive axles put in and bolted back into the hubs, and the front drive shaft installed) and then i took it out for a test run, when i did so and engaged the 4HI the front end started yanking the steering around about every 10-15 feet or so, or it might have been that the tires were pulling wrong or rotating wrong somehow at least thats kind of how it felt from inside the vehicle. so i pulled that one out took it back thinking that they sold me a bad front diff and got another with even less miles on it, now that i have that installed its doing the same exact thing!! if someone could please help me out and tell me what exactly im doing wrong i would be extremely grateful as i am about 30 second from filling the truck with tannerite and taking it out to and empty field and shooting it till it explodes!
thanks TX
thanks TX
You could try pulling it apart and reading the numbers from the ring gear of the front axle, but it is more difficult than popping the cover on the rear axle.
If you have never opened up the rear axle, it likely could use a good service. I wrote a tech article a LONG time ago that runs through that process.
