I Need some knowledge
Old Feb 7, 2010 | 09:53 AM
hoopride420's Avatar
hoopride420 is on a distinguished road
Exclamation I Need some knowledge
I was wondering if anybody else out there has ever done or thought of switching out the a arms and 4 wheel drive axles off an s-10 blazer and replacing them with the ones off a 1500.
The blazer already has a 700 r4 tranny so im assuming that the axles from the 1500 will fit into the transfer case but i would appreciate any help or suggestions.
Old Feb 7, 2010 | 02:34 PM
Axles and transfer cases don't fit together... The driveshaft does that part for you.
With that said, the suspension on the fullsize trucks is physically larger (wider, longer, etc) than the s-series stuff. This would require the removal of stock mounting points for the front axle and the upper/lower a-arms. It would be far easier to do a solid axle swap.
sloped39
Jan 1, 2013 12:06 PM
CaptainK
Jul 19, 2011 12:05 AM
2001Blue
Aug 5, 2010 01:41 AM
lowloudnproud1
Jun 13, 2010 01:34 AM
ivannj
Jan 18, 2006 10:44 PM
